Problem
Problem with Maxthon
Problem
Příspěvek 15. listopad 2015 18:13
Re: Problem
Příspěvek 15. listopad 2015 23:30
Hi and welcome to our forum :) Well, this isn't so easy. As the other guys said, for basic fields like login forms you can use the Magic Fill feature. Also if you type something, Maxthon usually stores it in the cache so even if you go back in history or some network error occured, you're able to restore the content (in most cases). But I am afraid feature which would analyze and store everything you type (autocompletion) isn't included in Maxthon (except the search/address bar).
Maybe you could solve this by an extension or script. I've found this extension (I am not sure if it works in MX4), maybe that's something what can help you, even if it isn't exactly what you're looking for.
I thought you could also store the text to Sky Notes via the context menu, but it seems it doesn't work for me :-O
